How to revive NiMH cells?
upand_at_them
Joined May 15, 2010
939
I have a pack of four AA NiMH cells that came with my charger years ago and never used them. They're probably about 8 years old. I just opened them and they all test 0V...the charger doesn't even recognize them. Is there any way I can revive them? I tried applying 1.2V for about 30 seconds and still got nothing.
Audioguru again
Joined Oct 21, 2019
6,826
Your old Ni-MH battery cells are finished. Buy modern new ones.
Energizer guarantees their Ni-MH cells for 5 years, used or not.
For the last few years, most Ni-MH battery cells use Eneloop chemistry that come pre-charged and hold a charge for 1 year to 10 years.
Audioguru again
Joined Oct 21, 2019
6,826
About 40 years ago I needed to zap (2200uF capacitor charged to 15V) shorted Ni-Cad battery cells. The zap burns out the metallic whiskers that form inside. Ni-MH cells do not form metallic whiskers.
38,847
Put a 20 ohm resistor in series with the battery and increase the applied voltage to get about 50-100mA of current (if you can).
Apply that for about an hour and then check the open-circuit battery voltage.
jpanhalt
Joined Jan 18, 2008
11,087
One of life's great lessons. NiMH is not NiCd. Each has advantages and disadvantages. However with the advent of lithium chemistry cells, NiMH may still survive awhile longer. NiCd is almost out.
