How to remove this protective layer?
quân nguyễn
Joined Jul 8, 2015
I have a device like in the picture.
It is protected by a layer of chemicals. Anyone know what that is chemicals.
And How to remove the chemical class and take power circuit ?
Thanks Everyone.
KMoffett
Joined Dec 19, 2007
2,918
It's called a potting compound. If it's hard it's an epoxy, and you are not to be able to remove it without destroying the circuit.
Ken
ian field
Joined Oct 27, 2012
6,536
Thanks Everyone.
There was a company called Oxley Developments that marketed a resin disintegrator solvent, but it might well also destroy the potted components.
Once I sat on the back step with a milling bit in the electric drill carving away at a Honda motorcycle regulator - it took all afternoon, but I did eventually manage to trace the circuit. The CDI unit from a later model even defeated the angle grinder.
