Below is an attachment with the main schematic for a Mastech HY6003D power supply. It was working great and abruptly quit putting out voltage. Using a second HY 6003D, I checked voltages in the circuit. It appears that the TL 431 is not operating correctly. There is 12 volts DC at the cathode and 1.1 volts DC at the Ref pin and .68 volts DC at the anode where there should be zero volts as it is ground. According to Texas Instruments datasheet, the ref voltage should be 2.5 to turn on the internal op amp and transistors. The attachment is labeled for a HY 5003, but the same schematic is used for 5 different voltage/amperage output power supplies.
What I am looking for is a more positive way to check the operations of the TL 431 short of just getting a new one and soldering it in. Thanks for the help.
DickW
DickW
