How to protect this MOSFET? Can I use zener diode or TVS between gate and source?
AlbertHall
Joined Jun 4, 2014
12,624
The opto-coupler supplies +5V to Q1 gate, but there is no path visible on your diagram to keep the source at 0V. If there is no such path Q1 will not turn on.
As to your question you can use a zener to limit the gate voltage.
Nazar Melnichek
Joined Mar 15, 2019
10
Can you recommend a default protect scheme? what kind of zener diode to use?
AlbertHall
Joined Jun 4, 2014
12,624
The maximum gate voltage is 16V. Your circuit will only supply 5V, so a 10V zener, cathode to the gate and anode to the source would do the job.
Note this bit of the datasheet below. The maximum your circuit can supply to the gate is 5V but you will lose some of that in the coupler so this will restrict the maximum current through the MOSFET.
danadak
Joined Mar 10, 2018
4,057
The MOSFET has a lot of gate charge to be handled, and a 220 ohm
R in its path, as well as Rsat_eff in the coupler output R.
What frequency/duty cycle are you driving the Gate with ?
Regards, Dana.
Nazar Melnichek
Joined Mar 15, 2019
10
Thank you very much!
Alec_t
Joined Sep 17, 2013
15,112
If the source of Q1 is connected to ground (at present the schematic doesn't show that) then the maximum Vgs Q1 sees should be 5V. Why do you feel the need to protect Q1 with a zener or TVs between gate and source?
Nazar Melnichek
Joined Mar 15, 2019
10
Because I can connect more than 5V to the drain, for example 24V, and when the optocoupler is closed, the gate is suspended, we can burn the transistor gate
danadak
Joined Mar 10, 2018
4,057
1 kHZ, but I can use up frequency
Your gate drive circuit not optimal so MOSFET will spend some time in
linear region dissipating a lot of power, depending on required load current
of course.
So pay attention to heat generated in MOSFET, maybe monitor its case T to
see if you are exceeding its data sheet limits.
http://www.ti.com/lit/ml/slua618a/slua618a.pdf
https://www.infineon.com/dgdl/an-937.pdf?fileId=5546d462533600a40153559ea1481181
https://toshiba.semicon-storage.com/info/docget.jsp?did=59460
Regards, Dana.
Nazar Melnichek
Joined Mar 15, 2019
10
of course.
Regards, Dana.
Okay, I'll read it
