How do you know that? You are not communicating with the pic correct? So how do you know which end is the problem?I have no issue with c# .net program
You're some detective. Does anything escape your spidey senses?What that tells me is you learned nothing from that other thread.
MplabX is not the best IDE / programming tool.. I doesn't report well.. Some compilers delete all the old files so a successful compilation replaces them with new versions... MPLABX however leaves them so an unsuccessful compilation isn't sometimes obvious... The stream of messages and warnings that spew out from the compile process confuses the best of us.... If you are unfamiliar with this it will confuse you...
Err Okay!! Lookup clean and build....I never had a problem with "old files". I am not even sure what what means.
I try not to use MPLABX, but unfortunately the TS has used it.. If he isn't aware that the hex file will still be intact even if the compile fails, well he needs to know... I also know that if there has NEVER been a successful compile, there won't be a hex file..
The funny thing is... I have modified the source code, and it still steps though using the old files...As I said.. I try not to use it.. The IDE has never really been as good as Ver 8.xx.
Until I desperately need it, it'll stay on the back burner..
Tell me about it.... I spent hours trying to get C# to spit out a serial string... Gave up and now I use Lazarus for my windows endeavours..The TS's problems are way more than the IDE.![]()
