Hello, I am implemented the circuit using a LTM2666 DAC to generate the high level and low level. I then used a LMH6738 triple output op amp. I tied the first op amp to the DAC high level output, tied the second op amp to the DAC low level output and the third opamp I tied to GND. I used a FPGA to control the three enables to each op ampl. I was able to generate the Vertical and Horizontal pules but my edges were more rounded that sharp.Hey great thread. I'm just wondering how well your solution worked in the end? Did you manage to feel tri-level sync to the camera you were using OK?
I'm working on a very similar project where I'm trying to make a custom tri-level sync generator to feed a Blackmagic Micro Cinema Camera which accepts sync on a little expansion port.
For what it's worth I actually took apart a Blackmagic "mini converter sync generator" to see how it worked. It seems their approach is to use a component HD video encoder (specifically the ADV7393) to output a Y/Luma signal that contains the sync pulse already - presumably they just output a test-pattern as this chip is able to do that.
Copying this approach is more code than I hoped so I've been trying to find other solutions which is how i've stumbled on this thread.
Mod: link to old Thread.
https://forum.allaboutcircuits.com/threads/how-to-generate-a-tri-level-signal.163522
Mod: Created new thread, link to old.
https://forum.allaboutcircuits.com/threads/how-to-generate-a-tri-level-signal-2.174282/post-1647294
Horizontal Pulse:
Here is the Vertical pulses:
I am testing the circuit with a camera now to see if the camera will lock to this signal. I have my doubts.
Thank you for mentioning the ADV7393 device. I see on page 80 of the datasheet they show Tri-level synch generation. I also see there is a Eval kit, "EVAL-ADV739X Evaluation Platform " which may be a good idea to purchase. However, the ADV7393 does not support 1080p only 1080i. I will need to find one that support 1080p at 60Hz.
Thank you very much,
Joe
