I have a device which consist of 3 memory Flash memory of 512KB, EEPROM of 2KB and SRAM of 512 KB.
First the connection is made through the software and then the programming is uploaded through Rs232. While uploading the the program is saved to SRAM. When i was running the program in device a message poped up that is
Erase Flash[F000]
Write Flash
[83]
From message i understood that the flash has been erased.
Now, the problem is that the device is unable to get connected through the software.
The supply is working fine, the LED indicator which use to check the working of the device at power on state is now complete of off, even i manually restart it.
But i think that memory may not been erased complete, i suppose my device might be hanged. Can i erase memory manually or externely
Erase Flash[F000]
Write Flash
[83]
