how to determine input impedance of a differential amplifier
Ghina Bayyat
Joined Mar 11, 2018
151
i need help please
in a bjt differential amplifier what would the input impedance be for the differential mode Not the common mode ?
i know the input impedance for the common mode = rπ + 2βRee / 2 but what would the input impedance for the differential mode be ? ofcourse it depends on the two inputs but how can i determine it ? isn't there an equation to use
Zeeus
Joined Apr 17, 2019
616
i need help please
Hi..Not sure
The answer depends on the configuration..If there is emitter resistor, base resistor...
From your answer for common mode then clear no emitter resistor(not the common mode resistor) and no base resistor..Btw, please why /2 in your answer?
(how did you write the pi and co?)..Anyways
think answer is beta * ( re + re||Ree)
With very large Ree or current source then becomes 2 * beta * re = 2* (rpi)
Answer for diagram included
What's answer if there are base resistors at both inputs?
Ghina Bayyat
Joined Mar 11, 2018
151
yes there isn't just the basic differential amplifier circuit ( but the picture failed to upload)
ofcourse there is because the two rπs of both transistors are shorted together in the common mode so they are in parallel so their equivalent resistance is half
u mean the sumbol ? there is a letter S above
but in the differential amplifier we use superposition to analyse the circuit and when we use it we kill vb2 and solve for vb1 then kill vb1 and solve for vb2 right
and when we do that one of the two transistors is common emitter and the other is common base and the input impedance of a Ce is rpi where the input impedance of a CB is re so isn't it supposed to be the sum of these two impedances or i missed something ?
Zeeus
Joined Apr 17, 2019
616
Wait...missed you response I guess
Input impedance is to find the resistance that Ib base current flows through, yh? Answer can not be Rpi + re
Not sure
look at base of transistor, every resistance looking into the emitter resistor has equivalent base resistance
Therefore input impedance Q
= (beta +1) *(re +re||Ree)
(beta +1) * re = Rpi ?
Ghina Bayyat
Joined Mar 11, 2018
151
Not sure
thanks for ur help but u can look at the links it is all cleared
LvW
Joined Jun 13, 2013
2,037
I think, this question needs - at first - some definitions:
(1) Common mode is clearly defined: Vb1=Vb2
(2) Unsymmetrical diff. mode: Vb1 finite and Vb2=0.
(3) Symmetrical diff. mode: Vb2=-Vb1
(4) General symm. mode: Vb1 finite and Vb2 finite (with Vb1 not equal to Vb2).
Input resstances: For the first three cases, it is a realtively simple task to find the dynamic input resistances rin (here given at the base of Q1)
Case (1): rin=rpi+beta*2re (re: diff. resistance of the common emitter path) .
Case (2): rin=2rp
Case (3): rin=rpi
Case (4): The input resistance at the base of Q1 depends on the signal Vb2 which is applied at the base of Q2. There is no textbook which gives an expression for the input resistance in this case (as far as I know). In this case, the input resistance must be calculated using superposition of the two cases (1) and (3). This is because each arbritrary combination of Vb1 and Vb2 can be split into the cases (1) and (3).
As the result, the formula for the input resistance will contain (and, thus, depend on) both input signals ! Therefore, no compact expression can be given.
