Thanks peterdeco. Sorry not too familiar with that. Is that a ADC input sorta like a voltage divider?I haven't read every post in this thread but referring to your 1st post, I am doing something very similar with a battery charging circuit. I use an 8 pin PIC microcontroller with an ADC input to monitor small changes in voltage. It is powered with 3.3V. If the ADC is configured as a byte variable with 256 steps, each step is 3.3/256 = .012V (approx). If configured as a word variable with 1024 steps, each step is 3.3/1024 = .003V (approx). Either one should have an ample amount of difference for the ADC to detect an off or on condition.
Thanks LesJones. I will see if I can build this circuit on a breadboard to know how this all works.In post #10 crutschow has given you the schematic to interface your + 1,25 to 1,95 voltage transition to a zero to +4.5 volt signal for the digital input on the Arduino. (Assuming a 5 volt version of the Arduino.) If you are using a 3.3 volt version of the Arduino then just adjust the resitor values on the output of the comparator. If you use the LM339 then you will need two of them for your eight channels as each one contains four comparators. If you don't want to build the interface then using analogue inputs will work. What peterdeco says in post #10 about PICs applies just the same to Atmel chips used in the Arduinos.
