Body
I am working on a power electronics project where I need to mix a 12V DC signal with a 1V AC signal and then amplify the output to achieve 20A while maintaining a bandwidth of 100 MHz. My current approach involves using operational amplifiers, but I am unsure about the best way to design the circuit to handle such high current without distorting the signal.
Current Setup:
Current Setup:
- Input Signals: 12V DC and 1V AC mixed using an operational amplifier.
- Goal: Amplify the mixed signal to 20A output without distortion.
- Bandwidth Requirement: 100 MHz.
- In the final application, I will be injecting noise into the signal with a bandwidth up to 100 MHz.
- Finding a suitable circuit design using operational amplifiers that can handle 20A output.
- Avoiding the use of transistors due to potential oscillation issues.
- Ensuring stability and minimizing noise in the amplified signal.
- What is the best circuit design to achieve a 20A output using operational amplifiers without distorting the signal?
- Are there specific components or configurations recommended for such high current and bandwidth?
- How can I ensure the stability of the circuit and minimize noise?
