How to decrease the Ron (On resistance) with given NMOS parameters
achen
Joined Sep 11, 2022
18
Given the NMOS model below from the Keysight ADS.
How do I decrease the Ron (On resistance) with given NMOS parameters, of course without changing the geometry of the NMOSFET (width and length)
du00000001
Joined Nov 10, 2020
200
When the geometry (length, width) is fixed, the only parameter remaining is the gate voltage: higher gate voltage -> lower Ron. Within the limits the oxide thickness allows.
Papabravo
Joined Feb 24, 2006
22,111
It is common for the increase in gate voltage to have a negligible effect past a certain level. If the absolute maximum Vgs is say +20 VDC, it would not surprise me to see the minimum rds(on) at about +10 VDC. Increasing Vgs past this point would be pointless.
