How to connect stepper to this curtain
shortbus
Joined Sep 30, 2009
10,049
Really looks like the motor is just stalling- not enough torque output to turn the roller.
That's why I never would have chosen a stepper for something like this, that and the complexity of the controller. A inline gear motor would be my first choice. Being DC they could be controlled with either an H bridge or as simple as a center off DPDT switch. Like this type -
quique123
Joined May 15, 2015
405
Oh I believe I have something like that...I believe the one on the right is actually a stepper? I don't remember but I think I pulled it off an old printer or scanner. The one on the left is a 34:1 geared motor.
Alec_t
Joined Sep 17, 2013
15,156
You will need some sort of further speed reduction with the motor on the left. 176rpm is rather fast for raising a blind.
quique123
Joined May 15, 2015
405
Ok I had ordered a more powerful stepper for this which I have now received but I recall when the previous one "unrolled" my curtain. So Im thinking my new stepper would also have that issue. Actually I sort of tried it by hooking it up to the curtain and just letting go a little bit and I felt it beginning to unroll so I just took it back off. The specs on it read Holding Torque: 1200 but no units. Im guessing g-cm cause further down the it reads 12 Ncm holding torque. Detent torque 1.6 Ncm
https://www.aliexpress.com/item/Bes...185.html?spm=a2g0s.9042311.0.0.477f4c4dGDSVxP
djsfantasi
Joined Apr 11, 2010
9,237
Usually that is when the motor is powered in a low amperage mode, not when it is really off. Some controllers allow this setting while waiting for the next command to move.
Exactly!
That’s why in this application, a geared motor is essential. Besides multiplying the torque, the gear friction assists in holding a position.
