Then better?"best" is undefined
I'm looking for smoother power supply basically. So is there any way to determine one depending on the given info in the datasheet thus I can test it out?Hello,
What criteria are important for choosing the DC-DC converter?
Is it efficiency?
Is it noise?
Is it size?
Thanks a lot. I'll check it out.Hello,
Switching regulators will always make noise.
They are more efficient as linear regulators.
Linear regulators do not create extra noise.
They are less efficient as switching regulators.
For the voltage difference you show, a LDO regulator will work.
The LD1117 will work upto 800 mA.
For higher currents look at the LT1083,LT1084 or LT1085.
Keep in mind that linear regulators will need cooling.
In order to make the kind of value judgement that you asked for you must define your requirements. Once your requirements are defined we can do two things:Hi,
I need to choose a 5-3.3V DC-DC converter.
I have been getting several products.
So please suggest how can I determine the Best one among them?
What are the characteristics I should be looking for into the Datasheets?
Regards
Start by defining your requirements.So please suggest how can I determine the Best one among them?
Hi Dennis,Start by defining your requirements.
- You say you want low noise? How low? Why?
- What about area?
- What about cost?
- What about efficiency?
- What power does the load require?
- What is the load?
- What is the power source?
- If source is a battery, what is the runtime expectation?
- Etc.
