Heating the wire with a solder blob on a wood block is how I do it when I have a few ends to skin and tin. It works well, and the charred block has a nice depression to hold the solder blob. It does help to have some solder flux as well, either from flux core solder or from a separate supply.@MrChips Thnak you for trying and confirming back !
@MisterBill2 im not lying when I said I was doing it inside a melted solder blob, with the wire at 1mm distance to the iron tip that was keeping the blob liquid. I did it on a piece of wood, not in air like in the movie.
I believe I dont have the temperature for it. By the ear, I'd say I need somewhere of 400 to 500 dgr Celsius in this range.
If someone here can experiment with heat on a 'normal' enameled wire, mine is 0.25mm diameter, and find under controlled temperature, what is the melting point of this insulator? I dont have any such precision heating wire or device, but maybe you do.
I was thinking on a MINIature heat inductance circuit, since I have that copper (conductor) wire that can get red hot and melt the insulator. It should evaporate the insulator... its the best idea I have (so far). But I really dont know if it will actually work, and also I have no idea how to build one (yet).
I don't think it only has to do with the heat in the example video, but also with the type of flux that it is in the solder wire. The reaction of the flux with the enamel is activated by the heat from the soldering iron. There are different types of flux available in soldering wire. Your soldering wire probably has less reactive flux.I try what you say and show me with the iron tip and the drop of tin (also from the movie), but is not working on my wire.
1- maybe the insulation that I have is more resistant to heat than usual, maybe is a very good quality insulator, like @MrSalts said, they are many type of cheap and good quality. If it helps, mine have a darker red color , like the very old transformers from the 90's and 80's. The copper wire color in the movie, was almost transparent and yes I could see how FAST it melted away under the tip of the heat iron. Mine is like cement in there. I like it actually to be this resilient to heat. But now I need it not to be.
2- The iron heat is not that hot. After watching the video, I remembered that I have a knob on my heating iron station , and I turn it to maximum, repeated the experiment with the tin blob drop, I even put DIRECTLY the tip of the iron on the wire isolation, I wait like 30s to 1min and NOTHING ! I mean, I have to really scrub in all this time to actually reach the copper under the isolation and to see that starting wire tinning. I didn't measure the temperature of the tip of my iron though. I THINK is around 300 dgr Celsius. 350 maybe? At its maximum. And I usually run it at 70-80% from it's knob.
I also tried the sand paper method, and in my case, is creating a long transition from wire end with exposed copper towards the virgin insulator. I guess im not that used on doing it with sandpaper. I have very fine sandpaper of 250 grit. And it worked excellent but with a long transition compared with the 2-5 mm (precise removal with knife) that I require.
Payback for all of your isopropanol that she has “borrowed” to clean the windows!Borrow the wife's nail varnish remover.
I don't think it only has to do with the heat in the example video, but also with the type of flux that it is in the solder wire. The reaction of the flux with the enamel is activated by the heat from the soldering iron. There are different types of flux available in soldering wire. Your soldering wire probably has less reactive flux. The type of enamel might also prevent the soldering method from working.
I have had success with high-concentration sulfuric acid (98%) to take off the ends of thin enamel (wire 0.4mm). I made diy Litz wire for motor winding. Note that it is the hydronium ions that react with the copper. Hydronium ions form when sulfuric acid is dissolved/diluted in water. It takes a while, and obviously, you should not leave it too long as it will eventually corrode the copper.
I 3D-printed a jig to keep the wires separate. This prevents capillary action from pulling up the acid along the wire where you don't want it. Set the length that you want stripped by adjusting the height of the acid in the beaker. After cleaning many wires the dissolved enamel fouls the solution a bit and it takes longer to strip. An improvement would be to clean the acid afterwards.
