How to calculate power dissipation for a signal?
coinmaster
Joined Dec 24, 2015
502
I want to use SMD mosfets near their dissipation limit without using too many of them in parallel.
I'm trying to understand how to calculate average power dissipation for an AC circuit.
Here is a clip from spice. Is the average power dissipation at the center point of the waveform or the top of the waveform?
shteii01
Joined Feb 19, 2010
4,644
mosfet datasheet should have a graph for it.
since you can not tell us the mosfet model, that is all the help you are going to get.
coinmaster
Joined Dec 24, 2015
502
I didn't ask for mosfet max dissipation specs, I asked how to calculate average power dissipation within a device that is passing a sinusoidal waveform.
shteii01
Joined Feb 19, 2010
4,644
You fail to understand that I am not talking about maximum.
In the datasheet there should be a graph (as in picture) that shows the power curve. Since your are the only one who knows what super secret mosfet you are using, you can take the data point for the x axis, find it on the curve and see what the power dissipation is.
DickCappels
Joined Aug 21, 2008
10,661
the answer to your question depends on the type of circuit that produces the sugnal, the nature of the load, and the amount of offset.
Picbuster
Joined Dec 2, 2013
1,062
Reference https://www.physicsforums.com/threads/power-of-a-sine-wave-electronics-engineering.320022/
This is still new to me too, but I recently found an article that might help you. I think you can use a ".meas" command to get average values over a defined time range.
http://www.analog.com/en/technical-...nd-step-commands-to-calculate-efficiency.html
Power (Sine Wave) = 1/2 * (peak amplitude)^2
This is not enough to do your calculations.
The current is the most important part I^2 x internal resistance at a given gate voltage is a measure for the heat.
The thermal- and electronic resistance are shown in the spec's.
A Fet in saturation 10^-2 Ohm does @ 10Amps 100 x 10^-2 = 1 Watt dissipation
But this is useless information is you don't know the thermal resistance.
That value will allow you to calculate the number of square mm PCB copper needed.
Picbuster
