How to calculate op amp output voltage?
WBahn
Joined Mar 31, 2012
33,186
You need to show your best attempt to tackle your homework problems. We will not work it for you, but we will look over what you have done and help you see where you might be going wrong and help you get past the specific points that are blocking your progress.
OldSantiago
Joined Oct 10, 2020
I know that R1 is useless, so does this mean that this is a non-inverting amplifier circuit?
Audioguru again
Joined Oct 21, 2019
6,826
Yes, that is correct.
An opamp has such a high voltage gain that when negative feedback is added then the output of the opamp will do whatever it can to make its - input voltage the same as the + input voltage. Since both inputs have the same voltage then R1 is useless with no current in it.
35,174
Here is the essential behavior of an op-amp circuit with proper negative feedback.
+Vinput = -Vinput
Just like what ag says above.
Take it from there.
LvW
Joined Jun 13, 2013
2,036
I know and realize that - as it seems - the question comes from a beginner.
And - as far as an idealized opamp is concerned - I agree that R1 is "useless".
However, for real opamps with a frequency-dependent gain the resistor R1 is NOT useless. It resembles a special kind of external frequency compensation - thereby improving the phase margin as well as the step response. More than that, using such a resistor across the opamps input nodes allows us to use opamps which are not unity-gain stable even with 100% feedback (unity gain).
The Electrician
Joined Oct 9, 2007
2,986
Hello there,
Would you like to know a very general method for handling these op amp circuits?
Once you get the answer to this i would be happy to post if you like.
Hello there,
Hi, MrAl,
Don't wait for the TS to solve his problem. I'm interested in your method, and others are probably also. Start a new thread in the general forum, Use some other circuits as examples.
MrAl
Joined Jun 17, 2014
13,791
Hi, MrAl,
Yes that is an interesting idea, thanks for the suggestion.
I wonder if it might be better as an article, or better yet, a new thread that might be able to be promoted as an article. I'll look into this.
WBahn
Joined Mar 31, 2012
33,186
For an ideal opamp (which I'm pretty sure is what you are assuming) R1 has no effect. For real opamps it can serve a purpose, but that's not where you are yet.
So, yes, it is just a classic non-inverting opamp-based amplifier.
But what is important is not that you realize that R1 can be removed, leaving you with a circuit that you happened to have seen before and can come with with a memorized formula for, but that you understand how to apply ideal opamp circuit analysis principles to an opamp-based circuit even if it is completely new to you.
