How To Ballast A MOT with a Flourescent Bulb Ballast
Dawn Marie
Joined Feb 10, 2017
http://www.usa.lighting.philips.com...cent-Ballasts/centium_fluorescent_ballast.jpg
I'm Wondering Just How Exactly Do I Wire A Normal BAllast Instead of using another MOT or a salt water resistor or something..just a normal ballast you'd find at Menards or Ace or somewhere..
because I have two and I'm wondering how I can wire those to work as a ballast for this one MOT so I can make arcs without worrying about tripping the circuit breaker
that's what it looks like also it has 8 wires .. 1 Black And 1 White ... 2 Blue Wires (shorter than the red and yellow wires) 2 Yellow Wires And 2 Red Wires..
Where Would I Attach OR Wire Those All To On The MOT
If you cant see the image the image can be found here https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwiit7qR4obSAhWh1IMKHW-hDioQjRwIBw&url=http://www.usa.lighting.philips.com/products/oem-components/fluorescent-ballasts.html&bvm=bv.146786187,d.amc&psig=AFQjCNEJ0rb8OzytZHQMpORYd8UrfIKubg&ust=1486858606759649
EM Fields
Joined Jun 8, 2016
578
The short answer is: "You wouldn't".
Dawn Marie
Joined Feb 10, 2017
what would happen if you did though... just two.. but also you wired a lot in parallel to be able to output the same voltage as the secondary coil
tcmtech
Joined Nov 4, 2013
2,867
It depend on the type of ballast you have. An old magnetic type would limit the current but new solid state one would do nothing being its output is high frequency (40 - 100 KHz) and thusly not compatible with the ironcore MOT.
If you want to make arcs then get yourself and automotive ignition coil and build a proper driver circuit or find a old fuel oil furnace ignition transformer or old neon sign transformer.
