How to asign a estate encoding to a finite state machine?
Gr10
Joined Feb 10, 2025
15
I need to assign a binary or one-hot encoding to each state of the following FSM:
I'd apreciate ir you could point me a methodology or general steps to assign encoding value for every circuit.
Papabravo
Joined Feb 24, 2006
22,111
You make a list of the possible states and then you can assign whatever labels you want to the result. A simulation may be helpful in creating a list of possible states, and noting that each flip-flop can be placed in the clear or "0" state by the reset signal, means you have a defined starting value. Next thing is to determine if any possible states are unreachable. If there are unreachable states, then you will need fewer than eight labels for the valid states.
ETA: State 7 = 0b111 is an unreachable state.
If X : = 0, the after 2 clocks the is equal to 0
From an initial state = 0b000, the state sequence is (0 1 2 5 4 6 5)* as lona as X=1
