How to activate a relay with resistance.
jerlam01
Joined May 16, 2023
Hey guys, nubey here, or more nubey than I want to be. I need help on a project where I'm looking to activate a relay when resistance is within a certain range. Is there anything out there I can buy? I looked in all the normal places but can't find anything. Resistance can't be a wide range and will need to be around 6k. Thanks for the help...
35,207
Sure can do.
Use the resistor in a voltage divider configuration (or bridge circuit) and apply the voltage difference to an analog comparator.
28,398
There is a circuit that is easily adapted to monitor a resistance. It is called a "window comparator. You will need to provide asupply to pass a current through the resistance so that you have a voltage to be monitored. It is cheap and easy to build and use. I am sure that such modules are available, the circuit is published in many places. But I would not look for it on yoo toob.
jerlam01
Joined May 16, 2023
What is generating this resistance and what is its range?
I have a resistor in an ice maker that I want to cycle the ice when it reaches 20K ohms. When warm water enters the ice maker the resistance goes down to 5k and as it cools down and freezes the resistance climbs. At 20k ohms I want it to close a relay.
AnalogKid
Joined Aug 1, 2013
12,281
It sounds like you have a thermistor, not a simple resistor. What is the power source you have available for a module or circuit?
So, you have a thermistor, and you want a relay to close when the resistance increases above 20 K, and open when the resistance decreases below 5 K. Correct?
If yes, this seems backwards. Wouldn't you want the relay to open (remove power) when things are cold enough?
Separate from that, there are a ton of mechanical and electronic thermostat devices / parts / modules on ebay.
ak
jerlam01
Joined May 16, 2023
ak
You are correct, what i meant is thermistor. Not sure why Im saying resistor. I need to apply power at 20k using a reversable polarity timed relay. anything under 15k would work to turn it off again.
35,207
Copied from post #3.
R3 + Rsensor constitute a voltage divider.
If the excitation voltage is 12V, for example, setting R3 = Rsensor = 20kΩ will give 6V at the junction.
R1 + R2 is your reference voltage divider.
If R1 = 20kΩ and R2 = 15kΩ, your reference voltage is 12V x 15k/35k = 5.14V
Thus what you need is a window comparator (using two comparators). Or use a single comparator with hysteresis.
When Vout exceeds (6 - 5.14)V = 0.86V the relay must turn on.
When Vout falls below 0V the relay turns off.
Adjust the values of R1, R2, and R3 to give you suitable switching thresholds.
Dodgydave
Joined Jun 22, 2012
11,395
That's a NTC thermistor , so a simple comparator circuit will work with a LM311 op amp.
28,398
I suggested a "window comparator in post #5. There may be an assembled one available as a module someplace. Having the name of the device makes the search easier.
