How ti use timer in PIC16F877A
phyllis
Joined Apr 25, 2015
1
I am doing noise detector project using PIC16F877A. How to turn on led if people make noise more then 1 minute?
22,111
How to use the timer in PIC16F877A
  1. Download the datasheet
  2. Assume a comfortable position
  3. Study the datasheet with intense concentration
  4. When you grok the use of the timer, proceed
30,795
One avenue to explore is using a clock crystal (32Khz) on the T1CKI input which can be used for seconds,minutes, hours clock.
In conjunction with a capture input using the CCP module. In your case the timer would be constantly reset if and when noise occurs, if none for 1 minute, it allows the clock to time out.
i.e. an interrupt would occur at the 1 min mark.
