I have a lot of experience driving DC motors but I've never worked with AC or triac's. I'm retired now but I've been asked by a friend to design a compact hydroponic system. The electric's consist of a control unit connected to a power bar. The power bar has 4 outlets controlled by 4 triacs. So my question is 1) is the circuit correct (see attached jpg) 2) how much of an inductive load can it handle. One inductive load will be a fan < 3A the other might be someone using an old ballast driving a MH or HPS light up to 600w. Can I avoid adding a snubber circuit?
Also the power bar will be rated for 15A max. from what I've read on the net I will need to dissipate about 12w of heat and need about 75 sq.cm. (12 sq.in.) of heat sink? I will be mounting the triacs on a 2mm thick rectangular (about 2.5:1) aluminum plate wall mounted on 1" spacers. One side of the plate will have the outlet enclosure over the triacs with limited ventilation I will consider this area as only 1/2 as effective. Does this sound about right? Also when a plate or a fin has both sides exposed to the air are both sides counted as surface area?
