How should I keep my soldering iron tip in good shape?
narkeleptk
Joined Mar 11, 2019
599
Always keep the tip tinned when sitting hot. Wipe just before soldering, and tin before putting back in holder.Also, tin before turning power off -- leave a blob of solder to protect the cold tip.
Remove oxidation with 600 grit sandpaper while hot. Re-tin.
I do pretty much the same, always wipe before and after each use an tin after. On top of this I use two irons. One with a large knife tip for rough work and cleaning up that does not mind the abuse and another one with a small chisel tip for clean work.
