How Relay Keeps Its Position
josepars
Joined Nov 28, 2018
73
Hi. I want to make RF card to control the relay.When I click the button relay will contact and will keep its position, when I push the button again it will be contactless and again will keep its position. How can I do that?
38,797
You can use a standard relay controlled by a D-Flipflop.
Controlling a latching relay with one button also requires some additional circuitry.
The main reason to use a latching relay is if you want the relay to use no continuous power in either state.
josepars
Joined Nov 28, 2018
73
I want to use normal relay to realize this project. Do you have suggestion for component?
