How multiplexer truth table works?
tshuck
Joined Oct 18, 2012
3,534
I would argue that the truth table is wrong - or, at best, misleading.
Row 4 seems to suggest that when the select (A) is 0, the output (D) is input 1 (I1).
A 2-to1 multiplexer works according to the following: When the select is 0, the output is the value of input 0, the output is the same as input 1, otherwise.
This means the equation is \(D=I_{1}*select+I_{0}*\overline{select}\)
33,283
While the truth table is that of a 2:1 MUX, the naming of the signals is very misleading. Also, in the e-book, the next diagram that shows the implementation is all but worthless since it doesn't include any distinction between the two outputs of the 1:2 line decoder.
A much better presentation of the 2:1 MUX truth table, in my opinion, is to put the select lines to the left of the table.
Code:
S | A1 | A0 || Y
0 |  0 |  0 || 0
0 |  0 |  1 || 1
0 |  1 |  0 || 0
0 |  1 |  1 || 1
1 |  0 |  0 || 0
1 |  0 |  1 || 0
1 |  1 |  0 || 1
1 |  1 |  1 || 1
