MisterBill2
- Joined Jan 23, 2018
- 28,207
For normal amplifiers rated at 150 watts output cap[ability, I would suggest step-down transformers rated at for at least 250 watts ,because the amplifier is not nearly 100% efficient. 300 watts is a good rating because the frequency is lower and so the efficiency of the transformers will be a bit less. I also recommend checking the temperature of the transformers in the amplifiers frequently for the first few hours of operation.
I also recommend getting a service manual for the amplifiers so that you can show us the circuit of the amplifiers. If they have a switcher mode power supply then the 50 Hz instead of 60 hz will not matter much.
