How does wireless charging work ?
Michael George
Joined Feb 8, 2015
62
I've heard about smartphones that support wireless charging. For me it's an amazing miracle!! I googled and found out that it uses something like a transformer for a wireless charging. I had another question because a transformer have an iron core and the two coils ( primary and secondary ) should be very close to transfer power between them... so I wondered how to get rid of the iron core and achieve long distance ? I searched again and I read about radio communications that uses "Resonance" to achieve long distance without using a magnetic core.
I have another question and that I don't find its answer, Radio communications transmit very small power. I think it is few micro volts because we use amplifiers to receive it ... so How can a charger send very large power to a smart phone through long distance and without magnetic core ?
Can I make a homemade device like that ? For example, I connect a homemade coil to an AC supply (low power) Then, I connect another coil to an LED. When I the coil is connected to the power, The LED is on ?
Thanks in advance, and sorry about my english :D
22,111
The reason we use an iron core in a transformer is to improve the coupling between primary and secondary. It is possible to build an air core transformer. As you move the primary and secondary coils further apart the coupling becomes weaker and weaker. In short it is not possible to "send very large power to a smart phone through long distance...". You might find the following article interesting.
http://en.wikipedia.org/wiki/Permeability_(electromagnetism)
t_n_k
Joined Mar 6, 2009
5,455
The reality is that the separation distance for effective inductive charging will remain quite small.
I have an electric toothbrush working on the same principle. Nothing particularly earth shattering about the concept.
To claim that the principle works sufficiently well to "send very large power to a smart phone through long distance" is an exaggeration, to say the least.
Next thing, someone will be claiming a device has been invented which can charge a smart phone by harvesting radiated power from other nearby smartphones. Then presumably, we'll have to download an expensive app which is claimed to stop this happening to our phone.
Reloadron
Joined Jan 15, 2015
7,923
The guy you need to talk to is Nikola Tesla who unfortunately passed away back in 1943, he had a good handle on how to do this. On a much smaller scale my electric toothbrush uses induction coupling to charge the battery. I think Tesla was a forum member here but I can't find any of his old notes.
Ron
Michael George
Joined Feb 8, 2015
62
I'm not a native English speaker :) what I meant by "a very large power" is about 3.7 volts / 1200 mAh which is the power of a cell phone battery. I said "very large" because I was comparing it with the power of radio waves.
Also, "long distance" is about 1 meter. I was comparing it with the distance between the two coils of a transformer.
t_n_k said: "I have an electric toothbrush working on the same principle"
I assume that the distance between the toothbrush and it's charger is 1 meter long or a little bit less. If it is, toothbrush's coil and charger's coil should transfer power that is similar to the power of radio waves because long distance makes magnetic field weaker. Moreover, the coupling between them is not improved because there is no iron core as Papabravo said.
That's why I think the power transferred between them is probably weak but practically, It is not weak. It is able to make toothbrush ( or a cell phone ) work..so would you tell me how the power is improved ? the only way I know is to make the two coils like a transformer (putting them too close with iron core).
You are too funny #12 :D I laughed too much when I saw your answer :D :D feel free to write in small font, I don't have a vision problem, I don't even wear glasses :D :D
GopherT
Joined Nov 23, 2012
8,009
1 meter is a very long distance. The guys who build the charging mats where you set the phone on a plastic charger (without plugging it in) have trouble with efficiency. That is about 2.5mm. So, yes, charging at 1000 mm is a very long distance.
And, if it were something that could simply be answered by a "how do I do this" on a forum, don't you think every battery powered toy and cell phone would have Ben powered by this etherial wireless energy for the past 20 years or more?
Read the bold print above.
22,111
Ron
He wrote them in the margins of his library books - ;)
PlasmaT
Joined Feb 19, 2015
61
I believe it can be done if only there was a way the direct the magnetic flux. For light we have lenses, so for magnetic field surely there could be a method to focus the magnetic flux to a region or along a beam. But with present know-how, it would be an inefficient exercise.
Reloadron
Joined Jan 15, 2015
7,923
Among the problems faced is for example cost. Unless something becomes cost feasible it simply isn't worth doing.
Ron
alfacliff
Joined Dec 13, 2013
2,458
transformers can be iron core, ferite core, air core or even two wires run paralell to each other. people forget that any two wires can cross couple hum, noise, emi, or what ever just by having any changing current flowing through it and another conductor near.
