How does this current source work?
matthej
Joined Oct 10, 2020
68
There is a design that has a current source to provide downstream. It is made up of an op-amp, 2n222 transistor and some resistors.
It is producing a current of up to 3.3mA. The drop across the 100 resistor is 3.3V.
I can't figure out how this is working. The input to the op-amp is from a DAC which ranges between 0 and 3.3V. The V_LaserA voltage is at +5V
38,807
Since you aren't showing the complete circuit, how can we analyze it?
But basically feedback keeps the voltage at the transistor emitter equal to 2 times the voltage at the op amp (+) input.
matthej
Joined Oct 10, 2020
68
Sorry didn't think the rest of the circuit mattered much. The current source goes to a device that is looking for current between 0 and 3.3mA. The other piece of the circuit goes to a diff amp which goes to an ADC for a telemetry measurement.
I am measuring a drop across the 100 ohm resistor of 3.3V when the input to the op amp is at 3.3V
Does that make sense?
tonyStewart
Joined May 8, 2012
238
Re-drawn to simplify, it is the unity gain differential amplifier, where we see the input pairs match at the left and also the Op Amp (differential null) inputs. But this part is not a current source.
28,272
The opamp is delivering enough base drive to the transistor to raise the inverting input voltage up to match the voltage at the non-inverting input. That circuit was shown in the `1976 National Semiconductor linear circuits book. It is classic and simple. The big caution is in avoiding having the acitive circuit voltages greater than the opamp supply voltages.
38,807
Below is the LTspice sim of the basic Howland constant-current circuit you have, for a constant 3.3V input and a varying load resistance.
The differential circuit maintains the voltage across the 100Ω resistor R5 equal to the input voltage, to generate the constant output current.
Since the input is differential, either input (or both) can be used to generate the constant current.
Note how the output voltage (red trace) increases to keep the load current constant at 33mA (yellow trace) as the load resistance increases (green trace) until the output saturates (at about 330Ω load resistance) at the maximum op amp output voltage (blue trace).
tonyStewart
Joined May 8, 2012
238
This doesn't look like what I drew above. The +3.3V should be on the + input of the op-amp
Thanks, Murphy's Law. If anything can be reversed, it will be.
As long as R1/R2= R3/R4 , the 100 Ohm being 0.1% introduces 0.1% error
You can modify any R, V and interactively understand why it works as a differential amplifier must produce the same voltage across the 100 ohm as the far left 3.3 to achieve a null error on the input. But the voltage reaches maximum with a load of 330 Ohms then current drops. But below it stays constant.
Transistor Pd= 375 mW max
https://tinyurl.com/yrgdftk9
matthej
Joined Oct 10, 2020
68
Thanks this is helpful . I am still trying to come up with the equations to get it such that Iload = Vin(3.3V)/Rsource(100 ohms).
I have a few equations, but can't get it reduced further. Can anyone help?
matthej
Joined Oct 10, 2020
68
Post your equations.
Referencing the circuit that tonyStewart shows above:
I am assuming V+=V-. calling this V : Also assuming minimal drop from base to emitter (is this ok(
i1=i2 => Vout -V/R2 = V/R1, which yields: V=(R1/R1+R2)Vout
i3=i4 => V-Vin/R3 = Vl-V/R4, which yields: V=(R4Vin+R3Vl)/(R3+R4)
I100 = Il + I4 => Vout-Vl/100 = Vl/Rl + Vl-V/R4
Now I am stuck and not sure where I go from here?
