dcbingaman
- Joined Jun 30, 2021
- 1,065
In either case, at AC you have an unstable second stage amplifier. It is going to vary all over the place based on changes in transistor gain and it will change with temperature as well. Distortion is guaranteed because the second stage gain is also determined by the bias voltage from base to emitter with will be all over the place for different amplitude AC signals. In fact the circuit might go into oscillation. Depending on cap values. It is not in any way a well designed amplifier.hi 123.
Surely you can answer this question.
Would you say the amplifier is designed for AC or DC amplification.?
The square wave is due to over driving the input.
