How does compiler place variable and structure variable in memory
Embededd
Joined Jun 4, 2025
204
So, when there is no data, I can visualize the memory like this:
Code:
Address     Byte 1   Byte 2   Byte 3   Byte 4
0x00       empty   empty   empty   empty
0x04       empty   empty    empty   empty
0x08       empty   empty    empty   empty
0x0C       empty   empty    empty   empty
Each row represents a 4-byte region. For example, the row starting at 0x00 represents addresses 0x00–0x03, and the row starting at 0x04 represents addresses 0x04–0x07.
Suppose we define a structure like this:
C:
struct test {
    char a;
    int x;
Let's assume a contains 'A' and x contains the 4-byte value 0x12345678.
With alignment, I understand the memory layout would look like this:
Code:
0x00        'A'        padding    padding    padding
0x04        0x12       0x34       0x56       0x78
Here, the 4-byte int starts at 0x04, which is a 4-byte boundary, so all four bytes of the int fit inside one 4-byte region.
Without alignment, the 4-byte value could theoretically start immediately after the char:
Code:
0x00        'A'        0x12       0x34       0x56
0x04        0x78       empty      empty      empty
Here, the int starts at 0x01 and crosses the 0x04 boundary. In the simplified 32-bit memory model we're discussing, the CPU may need two memory accesses to obtain the complete 4-byte value, followed by additional work to combine the bytes.
So I think the main advantage of alignment is that it can make memory access simpler and more efficient.
The trade-off is that we use some extra memory for padding. In this example, we waste 3 bytes of memory to ensure that the 4-byte int starts at a 4-byte boundary.
BobTPH
Joined Jun 5, 2013
11,618
My understanding is that RAM is not physically divided into fixed 4-byte blocks. Each address represents a byte, so the CPU can request data starting from any address.
Your understanding is wrong, as explained by multiple people multiple tines. If you start with a false assumption, you cannot get to the truth until you discard it.
The RAM used in PCs reads larger data blocks, which has changed over time, but more like 64 bits or more. The original 8088 had an 8-bit data bus as you assume, but everything since uses wider memory paths.
Here is Google’s summary:
The external data bus size in the x86 processor family ranges from eight bits in early budget variants up to 64 bits in modern multi-core processors. Bus widths scaled up across generations to match performance needs, transitioning from 8-bit and 16-bit designs to 32-bit and 64-bit standards. [1]
Early 8-bit and 16-bit Generations
    • 8088 / 80188: 8-bit data bus (used to lower system cost with 8-bit peripheral chips).
    • 8086 / 80186: 16-bit data bus.
    • 80286: 16-bit data bus.
    • 386SX: 16-bit data bus (cost-reduced version of the 386 line). [1, 2, 3]
32-bit Generations (IA-32)
    • 386DX: 32-bit data bus.
    • 80486 (and variants): 32-bit data bus.
    • Pentium / Pentium Pro / Pentium II / Pentium III: 64-bit data bus (despite having 32-bit internal architecture registers, the external data bus widened to 64 bits starting with the original Pentium to fetch data faster). [1, 2, 3, 4, 5]
64-bit Generations (x86-64 / AMD64)
    • Modern x86-64 processors: 64-bit external data bus, paired with extended internal 64-bit general-purpose registers and wider internal vector/SIMD data paths (such as 128-bit SSE, 256-bit AVX, and 512-bit AVX-512). [1, 2]
If you'd like, I can also break down the corresponding address bus sizes and maximum memory limits for each of these x86 generations.
Futurist
Joined Apr 8, 2025
939
Code:
C:
struct test {
    char a;
    int x;
Code:
Code:
Bear in mind, you are assuming a big-endian layout here, ARM processors can support big or little endianess, but the default is little endian, so the usual layout would be
Code:
0x04        0x78       0x56       0x34       0x12
finally, I'd recommend you say "unused" rather than "empty", those unused bytes will contain values, probably zero but not necessarily, every byte though always contains a value, so describing what it's role is rather than what it contains, will make your understanding to be clearer to people.
Embededd
Joined Jun 4, 2025
204
I think you may have missed my post #21, where I clarified that point.
You were right, I didn't pay attention to the byte order.
Yes I mean unused
Also, if the first variable is 1-byte long, there is no need to pad the unused three bytes. They can contain any 8-bit pattern.
Thank you for the point
33,076
It would be nice if you didn't attribute statements, especially wrong ones, to me when I'm not the one that made them.
33,076
Code:
I would recommend avoiding things like "empty" or anything else that implies that there is nothing there. There is ALWAYS something there. I prefer to use "unknown" or "?".
This is a trap that lots of people fall into, because they think that since there's "nothing there" that it somehow then behaves as if it has a value of 0 and then fail to catch uninitialized variables, even when they bench check a program by hand. I've seen it over and over, so it's valuable to adopt a convention that emphasizes that we don't know what is there.
C:
struct test {
    char a;
    int x;
Code:
This would be correct if your machine is big endian. For a hypothetical exercise like this, that's fine. But I'd recommend working in little endian since that is what most machines you are likely to work with will be and you want that to be the natural way that you think about things, if for no other reason that it is NOT the natural way that we tend to think about this.
If you want to label the pad bytes "pad" instead of "unknown", that's fine and probably what I would do, just always keep in mind that they still contain unknown values.
Now consider what the layout would be if you had:
C:
struct test {
    char a; // contains 'A'
    char b; // contains 'B'
    int x; // contains 0x12345678
There are two possible layouts that satisfy the alignment rules:
Code:
Addr    0     1     2     3
0x00   'A'   'B'   pad   pad
0x08    ?     ?     ?     ?
Addr    0     1     2     3
0x00   'A'   pad   'B'   pad
0x08    ?     ?     ?     ?
The compiler is free to choose either one and different compilers will make different choices. The same compiler may even make a different decision after an upgrade or if the compiler options, such as optimization level, change. The main point is don't get sucked into relying an assumptions about how the compiler is going to behave once you get beyond defined behavior.
BobTPH
Joined Jun 5, 2013
11,618
Sorry about that. I accidentally quoted the TS’s words from your post that quoted him. Did not mean to attribute it to you.
Embededd
Joined Jun 4, 2025
204
Thank you everyone for your help and for taking the time to explain this. I understand the structure padding much better now. I really appreciate all the explanations and corrections.
@Embededd
Compilers do a huge amount of work and determining addresses of variables is not trivial. One of the things a compiler does is create a "symbol table" that's a data structure that is created as the compiler executes.
The symbol table contains metadata associated with each declared variable. The first step here is to insert entries for each symbol as its encountered during the processing of the code.
The symbol table contains entries that describe:
1. The name
2. The data type
3. The storage type (static, stack)
4. Struct members (if any)
5. Size, alignment, offset
The details in step 5. are often unknown and are determined some time after the symbol entry has been initially added to the symbol table.
The "offset" here is a value derived from the offset of the preceding symbol, so it increases and depends on the offset and size of that preceding symbol.
So we determine size, alignment and offset of the first symbol then we do the same for the next and so on, for every symbol.
The offset too is either an offset into the static section or an offset from the start of the stack frame if its a stack based declaration.
Now for structures of course, there is more work to do, the symbol itself becomes a tree and each node of the tree is a symbol, and the process of determining offset is just a more general form of what I described above.
The concept of padding does not always need to be made explicit in the symbol table either, it just needs to be known when we compute the offset, it doesn't necessarily need to be recorded in the symbol table but can be.
Having said all that, understand that the code that's generated often includes a dynamically generated expression, called and "offset expression" and that is executed in order to get the actual offset at runtime for whatever variables are being referenced.
So in your example you have s.y = 10 and so the generated code will calculate some expression (a mathematical function) that uses the symbol table metadata for s and y.
The offset expression often is a constant value though because the offset does not change at runtime, so in the generated code you see just that calculated offset but if we have structs or arrays and combinations of these, the offset expression is in the generated code because it must be executed at runtime based on array subscripts.
Basically we want to calculate the address to write to, for every assignment and so the offset calculation does that.
Finally the symbol table is used as the basis for supporting debuggers and it appears in the final generated output file.
If you really want more insight then you must dive into some books, there is just too much work being done to deeply explain it in a post here.
i understood everything except the tree and node part ?? also why did you say that if we have combination of array and struct then offset is calculated at runtime not compile time, c doesnt support runtime array size allocation , struct also has fixed size so why would offset need to be calculated at runtime. maybe if these concepts are too much for this thread you can refer me some books i am an electronics engg student 3rd year just started:)
I wasn't referring to sizes, but offset.
outer[X].layers[Y,Z].member[W].counter = 0;
That's a runtime offset calculation, we must write 0 to some address not known at compile time. A compiler must compute an offset (from stack frame or static base) from X,Y,Z and W and metadata defined by the actual structure declaration - that calculation is an expression (often called an offset expression) - and the compiler must generate it, just as if the programmer had written it by hand.
By the way C does now support dynamic array sizing look for VLA.
This excellent 1969 paper by the late Bob Freiburghouse explains offset expressions (the paper talks about the PL/I language, but the concepts are the same) about halfway through the text.
https://multicians.org/pl1-raf.html
