Hi - I'm a student looking to build a test board for an IC. All the test sockets that I found at ARROW and Digikey look like this and I have mounting problems. The test sockets open and close nicely but that's all it can do. I need to affix the test socket to a something . There are no mounting holes on either side of the test socket. If I only solder it to the board, then I risk compromising the solder joint and weaken the wiring. I've tried to disassemble the test socket but the screws are too short to go to a PCB and if I tighten the screws on a board, the socket doesn't spring open.
How do you use this style of test socket and how does one screw it down to substrate or something ? How do I work with this ?? It seems like a dumb design if someone is constantly testing and ICs and needs to open and close the contacts . Much thanks in advance to those of you read this and help me.
