How do I make a SMA cable extension
RodneyB
Joined Apr 28, 2012
698
I want to extend the cable on a high gain Antenna to 5 meters.
I have the Antenna but not sure what the connectors are called or what type of cable I must use.
Any assistance and advice will be gladly appreciated.
38,634
How can we tell you what type of connectors you need with no info? :confused:
Can you post a picture of the connector or the socket they connect to?
PlasmaT
Joined Feb 19, 2015
61
wondering if I can cut and join the cable,
I don not recommend cutting RF related cables. It can degrade RF signal performance. Try and find the matching connectors.
Based on the RF power, the SMA connector vary in type and its has something to do in preventing consumers changing the antenna :) (see wikipedia on SMA connector)
