How do I get 3kHz signal?
RG23
Joined Dec 6, 2010
304
I am using PIC 16f887
I have a timer of 10ms .
I want to obtain 3Khz signal using this timer.
If anyone has an idea please let me know
Thank you
bertus
Joined Apr 5, 2008
23,005
You will never manage 3kHz with a 10mS timer.
The period time for 3 kHz is 1/3kHz = 0.333333 mS.
The highest frequency with a 10 mS timer is 1/10mS = 100 Hz.
RG23
Joined Dec 6, 2010
304
You could use the PWM output to generate 3kHz
_______________________________________________________________
What is that PWM output?
I have no idea on that
Please elaborate
RG23
Joined Dec 6, 2010
304
Check the CCP module in the datasheet. It's also handy for frequency generation
________________________________________________________________
What was the PWM output you were talking about?
Do let me know if I can actually create a 3kHz signal from 10 ms timer?
Thank you
spinnaker
Joined Oct 29, 2009
7,830
spinnaker
Senior Member
Actually its a different question
If you have any idea please let me know
Actually it is. It is PWM. If you learn how to do one you will know how to do the other.
But as we say in the States. "You are trying to get blood out of a stone". Meaning you are trying to do the impossible. As others pointed out, you need a much faster timer. Did you mean 10u seconds?
You can do it with a timer but you would need a faster timer.
It is actually easier to do it with PWM. Check the top of this subforum for a very nice post on how to do PWM. It is a sticky post.
