How do I fit these columns?
asdf arfw
Joined Sep 9, 2017
43
I don't know how to explain but here is my program which I wrote and the problem is the column like ID Midterm Final, it doesn't fit with the score below
like the example does. how do I solve this? and how do I turn int into float?
WBahn
Joined Mar 31, 2012
33,239
You read about "formatted output".
What do you mean by turning an int into a float? For what purpose? Give some kind of example to make it clear what you are trying to do.
spinnaker
Joined Oct 29, 2009
7,830
Please provide your code in text as opposed to a screen shot which is too difficult to read.
But my guess is that you need to use tabs between your columns instead of spaces.
And no idea where you are going with the int to a float either. Explain how this has something to do with your solution please.
xox
Joined Sep 8, 2017
936
Wikipedia presents a decent overview of formatted output for the printf-family of functions in this article. From my experience at least, the best way to go about it is to pass the width and precision settings as variables just to keep things as manageable and flexible as possible. Here's a simple example of creating left-justified output:
Code:
#include <stdio.h>
#include <stdlib.h>
#define COUNT 6
int
    main(void)
    int
        width = -12,
        precision = 2;
    const char*
        categories[COUNT] = { "ID", "Midterm", "Final", "Lab", "Score", "Grade" };
    float
        values[COUNT] = { 1, 38.8294, 67.981779, 24.4185, 91, 100.635 };
    for(size_t index = 0; index < COUNT; ++index)
        printf("%*s", width, categories[index]);
    printf("\n");
        printf("%*.*f", width, precision, values[index]);
    printf("\n");
    return 0;
Output:
You probably don't want the ID field to be printed as a float, but again, just an example to build on...
Umar19 Programming & Languages 0
