How do I find the value of the resistor with the zener diode on the image below?
WBahn
Joined Mar 31, 2012
32,817
So if you use a 450 Ω resistor and the load resistance is such that it is drawing 100 mA (when 7.5 V is across it), how much current is flowing in the zener diode? Is this enough to satisfy the knee current requirement in order for the diode to regulate the voltage?
Deshan Wolfey
Joined Aug 23, 2018
Current through Zener diode will be 0.09 A
ericgibbs
Joined Jan 29, 2010
21,439
hi DW,
Did you check your 450R answer.?
A simple error check 12v/450R = 26.6'mA maximum current draw , so 450R cannot be correct.
E
KeithWalker
Joined Jul 10, 2017
3,604
hi DW,
E
Look at the problem logically:
What you know:
The Voltage across RS equals the battery voltage less the Zener Voltage: YRS = 12 - VZen
The current through RS equals the load current plus the Zener current: RS = IRL + IZen
The maximum current through RS equals the maximum load current plus the minimum knee current of the zener: IRS max = IRL max + IZen min
Therefore:
The resistance of RS equals the voltage across it divided by the maximum current through it: RS = VRS / IRS max.
WBahn
Joined Mar 31, 2012
32,817
Could you please show/explain how you arrived at that? Without seeing your work, we can't even begin to guess where your reasoning is going astray.
Let's assume that you are correct and that, when the load current is 100 mA, the zener diode current is 90 mA. How much total current is flowing in Rs? What is the voltage drop across Rs if it is 450 Ω and that much current is flowing in it? Is that consistent with the problem?
