I have 110Vdc from a battery bank. Can anyone tell me how can i regulate these 110Vdc from 0 to 110V?
You don't say how much current you need, if it's only a milliamp or so, a potentiometer will do it.I have 110Vdc from a battery bank. Can anyone tell me how can i regulate these 110Vdc from 0 to 110V?
maximum current is about 1A.You don't say how much current you need, if it's only a milliamp or so, a potentiometer will do it.
i already tried with the potentiometer of 470k ohm 2W but it didn't work.You don't say how much current you need, if it's only a milliamp or so, a potentiometer will do it.
Depends how complicated you want to make it.maximum current is about 1A.
can you provide me the circuit diagram please?Depends how complicated you want to make it.
Just connect an MJ15003 as an emitter follower to the potentiometer. You will need a BIG heatsink.
| Thread starter | Similar threads | Forum | Replies | Date |
Building a DIY Regulated Buck Converter using no ICs (2) | Power Electronics | 10 | |
| T | 16 channel independently regulated 3.3v ic? | Power Electronics | 16 | |
| C | 12V 1Amp SMPS Circuit - how to make it as regulated? | General Electronics Chat | 8 |
