Homebrew power supply, circuit help
skeer
Joined Oct 28, 2022
134
Can anyone help me u der stand what’s going on here? There’s two transformers whose secondaries are confusing..IMG_0067.jpegIMG_0068.jpeg
sagor
Joined Mar 10, 2019
1,055
Looks like both are wired in parallel to the rectifiers to increase the current. Both transformers would be identical, and secondaries would be have to be in phase.
Externet
Joined Nov 29, 2005
2,676
Can clearly see two equal transformers with paralleled primaries (blacks) and paralleled secondaries (reds), paralleled filter capacitors and single bridge rectification to a transistor to control regulation.
skeer
Joined Oct 28, 2022
134
So those four big lugs are the diodes? If so resembles a battery charger. And the 2n2076a, I can’t find a datasheet on it. Also the two bit silver guys must be caps but I’ve never seen capacitors with threaded ends like those.
Dodgydave
Joined Jun 22, 2012
11,395
The transistor is a PnP germanium type, looks like the Negative rail is being controlled, by varying the voltage on the base.
28,344
I just disassembled an electronic counter that had the big capacitors with OCTAL plug in bases. It was a TUBE TYPE digital frequency counter, about 30 times the volume of my HP frequency counter. and it only was rated to 100KC. Lots of tubes, by the way.
AND, are those transformers really identical? one looks a bit thicker than the other one, but that may just be an illusion. And that lone PNP power transistor should have a better heat sink.
skeer
Joined Oct 28, 2022
134
Thanks fellas.. this is super interesting. I don;t quite understand why you;d use two identical transformers in this way..more amperage, got it. But also perhaps the guy just did not have one big one.
AnalogKid
Joined Aug 1, 2013
12,280
The two secondaries are in parallel to increase the available output current. The circuit is essentially one transformer, one diode bridge, two caps in parallel, and one emitter-follower output with a variable voltage to the base.
There is no reference voltage or feedback, so a percentage of whatever the cap ripple voltage is will appear at the output. The most simple mod to improve the circuit is to add an electrolytic cap from the transistor base to GND. Be careful with the polarity -- the + end goes to GND.
Is there any writing on either transformer or the pot?
ak
skeer
Joined Oct 28, 2022
134
Yeah so TBH I stole these pics off a FB marketplace posting.. primarily because it was interesting but also to try to ID the circuit and parts. I figured the output being unregulated and likely pretty noisy.
28,344
I thought that I sawa circuit for the assembly but now I do not find it. It would be simple to add a reference and make it a regulated supply, though.
