To build a high frequency amplifier circuit board
altered
Joined Oct 9, 2024
10
Project goal
To build a high frequency amplifier circuit board with specific input and output voltage and frequency requirements.
Scope of work
- Design a high frequency amplifier circuit board. - Circuit should accept inputs from 1-20 volts DC. - Support input frequencies from 0.5MHz to 6MHz. - Achieve an output voltage of 150 volts DC.
Papabravo
Joined Feb 24, 2006
22,059
i was hoping that would be part of the circuit
Generally speaking, an amplifier is designed separately from the power supply for a variety of reasons. If you want both of them together, then you need to specify both of them. This is particularly true when you specify a high voltage output. In this way if you need a specific amount of output power the supply can be designed to provide it. Of course, this now becomes a more challenging design task.
altered
Joined Oct 9, 2024
10
hi the output needs to be 150 volts dc
Papabravo
Joined Feb 24, 2006
22,059
An amplifier with an DC input of 1-20 Volts and a DC output of 150 V at 6 MHz does not make much sense. Do you mean that 150 volts is the maximum output voltage. You absolutely cannot have DC voltages in and out along with 6 MHz, or really any frequency other than zero, at the same time. It doesn't seem like you're too clear on the requirements. So, which is it?
altered
Joined Oct 9, 2024
10
Project goal
Scope of work
sorry people i made a mistake here is the correct needs
Circuit should accept inputs from 1-20 volts AC. - Support input frequencies from 0.5MHz to 6MHz. - Achieve an output voltage of 150 volts AC. The power supply either external 36v dc or internal which is better in your experience ts to power an ultra sound head
altered
Joined Oct 9, 2024
10
hi Sorry i made a mistake here is the correct needs
BobTPH
Joined Jun 5, 2013
11,480
So the output is 150VAC for a 1V input and 150VAC for a 20V input? And in to each of the following loads:
a. 1000Ω
b. 1Ω
c. 26pF || 157Ω
d. 1H in series with 3.5Ω
e. 5mH || 2uF series with 7Ω
Right?
BobTPH
Joined Jun 5, 2013
11,480
Oh never mind, I just reread the post. You are designing a circuit board for an amplifier, not the amplifier. So post the schematic and parts list.
27,255
It is difficult to imagine that an ultrasound system would have such a wide range of input amplitudes from the excitation section. And what sort of load will it be driving. And the ultrasound frequency spectrum does not go down into the audio range.
So please let us know just what the application is, because the description does not seem to match my understanding based on other information, which was not recent, I admit.
ronsimpson
Joined Oct 7, 2019
4,654
It appears there is a 36V supply. By using bridge amplifiers we can get about 60 volts peak to peak. (two 30V p-p amplifiers)
It will be hard to do 150V at 6mhz in a single amp. The volts/second is very high. It is hard to find high voltage parts. Years ago we worked on a 30V amplifier that used a transformer to get up to 150V.
We need to be certain we are talking about the same thing. When measuring ac voltage, there are three different ways.
Vpp is peak to peak. Vpk is the 0 to peak, then there is average and Vrms which can be the same.
Where I live the power line is 120Vrms which is 170Vpk and 340Vp-p.
Papabravo
Joined Feb 24, 2006
22,059
I'm guessing that a traditional Class C amplifier will be a sub optimal solution and so I'm about to look at Class D & E. Not too familiar with parts that work with those voltages in that frequency range. I hope you're not in a hurry.
27,255
Really, the required performance can be achieved by a pair of 6L6 power tetrode tubes. But it will be far from small or cheap, and it will require a more capable power supply.
I am not recommending that scheme, although it would easily meet the original specification.
