Hex to ASCII for display
mukesh1
Joined Mar 22, 2020
68
Lets say we have HEX value,
(byte & 0xF0) // send upper nibble
((byte << 4) & 0xF0); // send lower nibble
How do I convert HEX to ASCII and display on LCD without sprintf itoa ?
Dave Lowther
Joined Sep 8, 2016
347
If your byte contains, for example, 0x41 which is the ASCII code for 'A' what do you want to show on the LCD "A" or "41"?
click_here
Joined Sep 22, 2020
548
You have 2 numbers...
Code:
lsb = number & 0x0F;
msb = (number & 0xF0) >> 4;
If the l/msb is below 10, add '0'
Code:
lsbAsASCII = lsb + '0';
If l/msb is 10 or over...
Code:
lsbAsASCII = (lsb - 0x0A) + 'A';
35,041
C:
lsb = (byte & 0x0F);
msb = (byte & 0xF0) >> 4;
lsb = (lsb < 10) ? lsb : lsb + 7;
msb = (msb < 10) ? msb : msb + 7;
lsb += '0';
msb += '0';
ApacheKid
Joined Jan 12, 2015
1,762
There is an alternative approach, rather than executing code for this create a lookup table, this will execute pretty quickly.
input of 0 -> '00'
input of 117 -> '75'
input pf 255 -> 'FF'
Of course if you cant spare 512 bytes then this won't be possible but if memory is not too constrained this is a neat option to consider. With some additional simple code you can just have a table of 16 bytes not 255, but that needs a bit of division.
