Then you should explain what you do know, or what you think you might do. We aren't going to be doing your work for you...How do you solve for R4, if I knew how to do this, I wouldn't ask yall
So you post a circuit without showing any work saying that you don't know where to start. So I focus you in on one resistor and suggest that you start there. But then you won't show any attempt and say you don't know how to do it.How do you solve for R4, if I knew how to do this, I wouldn't ask yall
No. You are making a pretty common mistake. You are trying to throw an equation at a problem without understand what that equation means. So you see that you need an I and a V and so you grab the handiest I and V and crank away.V=IR
10V=0.2(R)
R=50ohms
Is this correct?
