HELP
shahpoor71
Joined Oct 2, 2014
3
Hi
Please help me if you can
I need a three-circuit DC / DC Converter
1. The boost converter with the following specifications:
One of the following IC circuit: TL 494 or SG3525 OR SG3524 or MC34063 or UC3843 OR UC3842
VI=5
VO=15
FS(MOS)=30KHZ
IO=2A OR 3A
2. The bUCK converter with the following specifications:
VI=15
VO=5
FS(MOS)=30KHZ
IO=2A OR 3A
3. The (BUCK/boost) converter with the following specifications:
FS(MOS)=30KHZ
IO=2A OR 3A
The input voltage to the desired output
If the circuit is protected against overload and short circuit as well
And if possible adjustable
Thank you very much wait for your answer
ian field
Joined Oct 27, 2012
6,536
Hi
VI=5
VO=15
FS(MOS)=30KHZ
IO=2A OR 3A
VI=15
VO=5
FS(MOS)=30KHZ
IO=2A OR 3A
FS(MOS)=30KHZ
IO=2A OR 3A
Most of the devices you mention are well supported by online appnotes, the MC34063 has some online component calculators that make designing a breeze.
Buck/boost can be a bit tricky, there's various names like Cuk and Sepic you can google for types of designs - if you want to keep it simple; you could just feed a buck with a boost.
shahpoor71
Joined Oct 2, 2014
3
My friends, my English is not so good
So all the talk and taunt you just do not know
Just wanted to say I need help I am not josh
Thank
djsfantasi
Joined Apr 11, 2010
9,237
Ok. I'll ask after promising that I am NOT taunting. Your English is better than my Iranian. But, I do not know what you mean by "josh". Is there another word you could use to help me understand?
34,817
There are over 751,543 messages on AAC. There is a simple reason why "HELP" is not a good title.
It would be rather stupid if many messages called for "HELP".
So think about it. "HELP" does not help anyone trying to sort through messages.
Next time please be more considerate.
