I'm trying to add a solenoid to a gasless welder, iv added a euro torch all ready but I'm struggling with the solenoid.
The control board is 12v, iv tried connecting the solenoid to the return from the mig trigger and connected the neutral of the solenoid to a GND pin on the board but when the solenoid is connected is stops the mig from working.
Would using a relay off the mig trigger be a better idea and fit a PSU for the solenoid?
The little transformer doesn't Show a amp rating so I'm unsure if the solenoid is pulling to much it's ment to be rated at 0.40ma so I wouldn't of thought so but Unsure
The mig trigger is the bottom right connecter
