edit:
I'm trying to study about a transimpedance amplifier (TIA). I'm using LTC6268-10 op-amp configured as TIA. I'm using it to get power readings from a 1310nm photodiode, which I'm reverse biasing it in TIA. Datasheet of op-amp I'm using: link.
I have referred many application notes on stabilizing a TIA circuit. Like from TI here: link.
From what I understood is, we should select a feedback cap such that fp lies between fz and fi (refer the inserted image).
This is for unity gain stable op-amp.
![tia_stability.PNG tia_stability.PNG](https://forum.allaboutcircuits.com/data/attachments/305/305397-1b42f2d2622c69d4d6e49445c3746207.jpg)
My question is, does this same stability analysis hold true for de-compensated op-amps as well? How it is same or different? Could someone please help me with this?
I am trying to prove stability for my LTC6268-10 de-compensated op-amp that I'm using for my TIA design.
I am using the word "prove" because I'm using a feedback capacitor that should make my TIA unstable as per the design given in the op-amps datasheet, but for my experiment the TIA is working fine! So I have to know why it is working![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
