Help with phasor diagram
Cassy85
Joined Oct 3, 2021
Hi all, I'm new to the forum. I'm looking for help with the following questions I have uploaded.
Any help would be greatly appreciated.
Thanks in advance.
Moderators note : cropped image and showed full size.
Cassy85
Joined Oct 3, 2021
This is what I have attempted so far.
It's question 2b I am really struggling with.
I'm not looking for the answers just looking for some direction.
  1. Calculate phase current
Phase current = 250003 x 415 x 0.8
Phase current = 25.1 Amps
cos-10.8=36.87
I = 25.1 ∠36.87° Amps
  1. Calculate the stator reactive voltage drop IXs
Voltage drop = IaXs
25.1 x 4 ∠36.87° + 90°
Voltage drop (IXs) = 100.4 ∠126.87° volts
dcbingaman
Joined Jun 30, 2021
1,065
Watts multiplied by Volts does not give you Amps.
There appears to be something wrong here just from dimensional analysis. Power being voltage times current. I would think the correct formula would be 25e3 (W)/415 (V) = 60Amps * (0.8) = 48 Amps.
Watts over volts gives amps and power factor is a unitless quantity. But I am not 100% sure. I have not dealt much with problems involving 3 phase delta connected synchronous motors.
BobaMosfet
Joined Jul 1, 2009
2,211
@dcbingaman is correct. The basic formulas are Ohm's Law and Watt's Law I = E/R
Papabravo
Joined Feb 24, 2006
22,111
... power factor is a unitless quantity....
This is absolutely correct. Angles are dimensionless (unitless) since they are the ratio of two distances. Any transcendental function of a dimensionless quantity is also a dimensionless quantity. Power factor is the cosine of the phase angle between the voltage and current of an AC waveform.
