Help with Mini Solar Charger
Knowlittle
Joined Mar 16, 2016
45
Hi all hope you can help. ..... i have a small 5v solar panel and want it to charge 2 rechargeable AA batteries. Whilst charging (while sun is shining) LED 1 Must be illuminated, whem the sun sets LED 2 must illuminate and LED 1 must switch off. Then when the sun comes up yhe following morning the cycle must start over ! Hope you guys can help (PLEASE MAKE IT SIMPLE ) Thanks.
Kermit2
Joined Feb 5, 2010
4,159
Simple would be a few diodes to drop the voltage and a direct connection to the batteries needing a charge.
LED's that light and go off based on charging cycles is complex and requires a controller.
Have you done ANY Google searching for charge control circuits?
Alec_t
Joined Sep 17, 2013
15,125
Unfortunately, to do what you ask reliably is not simple :(. To prevent battery over-charging or over-discharging you'll require a controller, as mentioned. You will also need a light/dark sensor with a certain amount of hysteresis to prevent flickering at dawn/dusk.
jsallas
Joined May 17, 2016
9
Mr. Kermit is right. The simplest way is using diodes to drop the voltage. Of course this won't be an "smart charger" and won't prevent battery overcharge.
Adding to this, you need to put some protection diodes to the lines feeding the panel. If you don't do this, the solar panel will behave as a resistive load when it is shadowed or not exposed to light, and it will drain your batteries.
For the LEDs, you might need a controller or a voltage comparator and fix a treshold voltage (with hysteresis) to compare with the panel output.
The comparator output should be able to drive an LED, or to switch a transistor if more LEDs are needed.
Knowlittle
Joined Mar 16, 2016
45
Ok let me explain differently, the sunlight will act as my "sensor", i will add additional resistors to the circuit to prevent overcharging i basically just want for the leds to charge in the day and as soon as the solar panel gets no more light for them to illuminate.
