Help with LM386 Amplifier
Ronak Bera
Joined Apr 6, 2019
Please help me to remove noise from Mic. we interface with LM386 Amplifier IC. We want to remove humming noise. so please give me solution.
DickCappels
Joined Aug 21, 2008
10,661
Use short wires between the microphone and the LM386. Make sure the wires are twisted together and/or are shielded, connect the shield to ground.
Do you have a schematic of your circuit?
What kind of microphone are you using?
What are you using as a power supply?
34,807
Hum in an audio amplifier often occurs from poor power supply filtering.
Power your project from batteries and see if the hum diminishes.
bertus
Joined Apr 5, 2008
22,922
As said, the hum can be from a poor power supply filtering or from pickup of an unshielded cable.
By battery powering the circuit, you can determine wich influence makes the hum.
Bertus
