I'm almost embarrassed to post this one... it's so simple but I just want to be sure I have it right. I have attached a schematic. This is for an automotive application. I have a ground connection for pin 1. I want to power a device using the Remote (switched power)… and the mfr. recommends fusing it at 1A. The switch can easily accommodate that load, so how do I wire this? I always get these simple ones confused. I think more like a computer than like an electrician. Is this switch normally open? do I hook my positive source to pin3 and my output to the device to pin 2 then ground on pin 1, or do I connect the source to 1 and the load to 3, and if so what do I connect to 2? Thanks for any help.
