Help with grounded shielded load cell in plastic enclosure
kyleh04
Joined Jun 18, 2017
54
Hey guys,
I'm working on a project in which I am using a parallel beam load cell with two plates (not metal) to weigh objects within a plastic box a couple feet tall.
The load cell I'm using uses a shielded cable, and I am unable to put a hole in the container to connect it to physical ground. Should I just ground it to the ground plane on my MCU?
Also, if I use a metal container, it will be a couple of feet tall, should I still ground it to that container, or will that act as an antenna?
Thanks a lot in advance!
ericgibbs
Joined Jan 29, 2010
21,536
hi k,
When I use a L/C with a shielded connecting cable, I always ground the screen at the electronics, MCU.
Likewise I would ground a metallised enclosure in order to provide a screen.
E
kyleh04
Joined Jun 18, 2017
54
hi k,
E
OK great, that's what I assumed.
Since I won't have a earth ground with the plastic container, is it safe to say that the best screen will be with using the metal container?
