Could someone point me to where I can research, measure, calculate, and/or size these ferrite rings if voltage and rough max amps are known?
It's for 5, 12 and 24VDC low power system pulling up to 2 to 3 AMPs per run. Some amps are far lower.
Also would like advice about bundling several loops in one ring, or what to stay away from, how small of AMPs when it doesn't matter, etc.
/tr;dr
I have a problem. I've been collecting a lot of used 3D printers and repairing them. It all started when our daughter won a 3D Printer. And then COVID hit, so we've been doing 100s of PPE since. I am sitting on 7 3D printers now, with 3 functional (repaired two, and working on the others).
I noticed that all of these printers suffer from sever EMI. All of them, except the 3 very expensive Dremels. If you move any axis, extruder, anything with a motor, then the LCD display will light up, cooling fans start to spin, and even some other other axis may move if you do it fast enough.
The 3D printing community doesn't seem worried. "They all do that."
However, I noticed these Dremel 3D45s and 3D20 she won all don't suffer from many EMI.
Pulling the covers off, I've noticed the key difference is that the Dremels all use ferrite magnet rings around almost every cable. Some cables are bunched up into a single harness with a single ring, most others are isolated with their own rings.
I recall EMI and how these ferrite work from my electronics classes 30+ years ago. This is what I want in my first DIY build.
However, I have no idea where to start calculating and sizing them, what models are better than others, and even if there is a specific direction.
Thanks for your time!
Below are pics of the Dremel 3D20 and its different-sized and types of ferrite rings. How do they calculate which ones to use?
/tr;dr
