I'm struggling to get something presumably straightforward, to work.
I'm trying to use DMA to pump a 4K sine table (precalculated) through a DAC on my Nucleo-F446RE board.
I've successfully had this working where the app just loops and writes the values from slot 0 to 4095, over and over and that works fine, I see the expected sine wave on my DSO.
Now I've modified this to use DMA and need help, I can find no concrete example of this for my specific board. I am also using a book Programming with STM32 (by Donald Norris), not a bad book but again this specific example isn't covered.
I also used Cube to generate the initialization code for the various peripherals.
So my question is this, can anyone see anything obvious missing from this main function?
