Hi, just found this thread which was the only thread or info relating to repair of my Ecoair DD3 on the internet!, i purchased the unit around 5 years ago, my problem is that the unit has stopped collecting water which I gathered was due to the heater stopping working. After dismantling, I tested the thermal fuse which is clamped to the heater housing in a plastic sleeve together with a thermistor. The thermal fuse is directly in line with the incoming mains cord, both components were fine, however I then realised there was a thermal cutout - a seki ST 22 hidden under a grommit..secured by a screw (see photo) which is in line with the neutral feed for the heater. This read open circuit so is hopefully where the fault lies, I have a spare arriving in two days time so will update. I suspect the device has given out due to the mains cord being unplugged before the heater has cooled down, hopefully this is helpful and thanks to others for originally posting as it gave me plenty of clues!
